Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Questions View all
Question Closed
replacement hard drive AT111
my original hd just crashed. It is listed as SATA.
can I install a 1tb Toshiba AT 111 in it's place?
any connector issue?
5 Comments
Please give us better information on this Toshiba.
by
thank you for your response,
here are the specs
Product Height 0.4"
Product Width 2.75"
Product Weight 4 oz.
Product Depth 3.9"
Internal or External Internal
Drive Capacity 1TB
Drive Connectivity Serial ATA III
Rotation Speed 5400 rpm
Data Transfer Rate to/from Interface Up to 6 Gbps
Average Seek Time 12 ms
Cache Buffer Size 8MB
System Requirements PC: Windows 98 SE, Me, 2000, XP or Vista; Mac: OS X; Linux
Laptop or Desktop Laptop
by
New 1 Tb drive installed, partitioned into 2 segments and working fine.
I assume that the drive auto negotiated transfer rate.
Thanks to all for help.
by
Glad we could be of help ;-)
by
drive worked fine..I think it auto negotiated transfer speed.
thank you everyone for your help
by
Add a comment
Chosen Solution
This drive is a 6 Gb/s speed drive. Your Mac most likely has a 1.5 Gb/s bus speed. You will most likely need to jumper it down in speed for Disk Utilities to recognize it.
Score 1
3 Comments:
You are correct. Bus speed is 1.5Gb/s
New drive arrives next week and I will install it.
If I need to change jumpers, which jumpers?
Perhaps the answer will be with the Toshiba drive instructions?
by
I need the model number of the drive to be able to look that up.
by
Toshiba Model: PH2100U-1I54 • SKU: 6915678 (1Tb )
by
Add a comment
as long as its formatted correctly any hd will work
1 Comment:
thank you for your response.
I expect to receive the new drive next week and will publish result.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 181
