Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3230 Questions View all
Stuck Power Button iPhone 4
my iPhone 4 power button looks smashed , it is stuck .
I already open it , and it looks normal but still stucked. Which part i need to replace ? The button or the flex ? Hope you can help me
Add a comment
Chosen Solution
You need to replace the power and proximity sensor flex cable.
Here is the guide.
iPhone 4 Power & Lock Button Replacement
The part is under relevant parts.
Hope this helps,
Score 1
Add a comment
Turn on Assitive touch
Add a comment
If the button looks smashed you only have to replace the button. You won't need to replace the flex that's just silly talk there
I would take out the two screws that hold the power button and make sure the spring in the button is not broke
But the button dont looks smashed , it only does not click !
Add a comment
Add your answer
Ricardo will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 18
All Time: 5,869
