Apple's line of iBook laptops was intended for the consumer and educational markets. The iBook line comprises of the iBook G3 Clamshell, G3 12", G3 14", G4 12", and G4 14".
1133 Questions View all
How can I replace my power source?
My mouse pad doesn't work any longer. I already replaced the battery. G4 12"
Comments:
Do you want a trackpad or a power adapter? In either case I need the exact model number. That would be under the keyboard or battery normally but could be printed on the bottom of the computer. Get back with this information and we will try to help you. Ralph
by
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
First hook it up to an external keyboard and mouse to make sure of what is working and what is not. Try using a thin hard piece of plastice and run it around the seams of the mouse to try to dislodge any thing that might be obstructing its function. That failing do as rj713 suggests.
Add a comment
Add your answer
Doug Wolven will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 915
