Spilled water on my laptop it wont turn on,what do I do?
A glass of water was knocked over spilling on to my laptop (Compaq Presario cq62) keyboard. well I turned it upside down so the water could spill out then I turned it on to see if it worked and it did BUT when I was trying to type in my password some buttons wouldn't type and some would, well when I tried to delete it wouldn't delete instead the delete button would add a letter each time pushed. So I took the battery out n turned it upside down and it stayed like that over night, well now we tryd using it but it wont turn on at all even if the charger was plugged in to it ,the laptop wont even turn on make any noise or lightup . what should I do or dos anyone know what could be the main problem!
Comments:
have u had any luck? I've had the exact same thing with my laptop too
by
Same thing i also experienced with my laptop and given it to service center and it is working now. But the problem am facing is whenever i turn on the laptop, every time i need to set the date & time setting & it is not saving also. Some body please tell me what i have to do now.
And also it is asking for battery replacement.
by
replace button cell on your motherboard.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Amanda, the main problem could be the repeat attempts to turn it on. I strongly suggest that you remove all power sources, like battery and AC charger from the computer. Once that is done, disassemble it using the service manual from here. Clean all the parts with +90% isopropyl alcohol. Check for any burnt or charred, or missing components. When it is properly cleaned, re-assemble and re-evaluate for any damage. Right now the number one priority is the cleaning to avoid further corrosion damage and to prevent any shorted circuitry. Hope this helps, good luck.
Score 1
Comments:
Hey thanks for the answer, but i did all that my computer cant go on if the keyboard id plugged in, unless i disconnect the keyboard
by
Mathy try a USB keyboard to see if that works. Ultimately it sounds like your keyboard shorted out. Replace it.
by
I spilled milk on the bottom of my Acer chromebook and it won't turn on at all. I charged it to see if it was dead and it still won't turn on. What do I do?
by
Hello i spilled water all over my closed laptop computer during the night I noticed it two hours after the incident. ( It wasnt on) I tried to get it to a dryer place to wipe it up and there was a pool on the top of the closed laptop. I cleaned it up and when I opened it and inspected the key bard I could tell some water got insinde due to water in some of the gaps of the mouse and some keys. I had to wipe the droplets and continued to inspect it. It was charging when this happened but the charger still works. So I took the male part of the charger out and it had a dot of water on it. After I dried it out for the most part I tried to turn it on. It wouldnt on. So I plugged it back in, No dice, Flipped it around and took the charger out, no dice, kept the charger out and left it alone till morning, still no dice, tried it after work still no dice! What Should I do?
by
@stupidsignup you need to progress the as way as described in the original answer.
by
Add a comment
Hi if you spill water on Laptop, its very easy to get rid of it. I put my keyboard side to a very close distance from my heating panel. it should be upside down. after 10 hours i turned it on, and its working perfect.
Comments:
what are you going to do about corrosion?
by
Add a comment
First step you need to take is remove power cord and battery. Water generally contains ions which act as a conductor. Without electricity, your electronic components can not short out. It may be too late but it may salvagable.
Second step is remove the screws and all covers from the back. Laptop needs to be open and all components need to "breath". The reason for this is water tends to evaporate. If the water vapor has no place to go it condenses back on your components. It needs to evaporate away from your components (aka: in the atmosphere).
Now place the laptop in the sun for a day or two (depending on how much water you dumped on the laptop). You can speed up the process with a hair dryer if you are impatient but I would not recommend it.
After two days in the hot sun, pop in the battery and see whether it boots. If you components were not shorted, you should be ok. If they were damaged, try an external keyboard. It should work. Good luck and let me know what happens. Keep in mind that it is imperative that you do not have any electricity running to the machine from power cord or battery while it is wet.
Comments:
thanks for your brilliant advice, you ar a pro
salem
by
Add a comment
Hello, I recently spilt water on my laptop keyboard, I simply wiped it off and every key worked just fine, and so did the computer. My keys were a bit sticky though so I decided to take my laptop battery out and clean the keys. After I did so, my laptop wouldn't turn on, so I removed the battery, pressed the power button for 20 seconds then plugged in the laptop without the battery and tried turning it on. I looked online for reasons but nothing worked. I decided to give it time and close the laptop, placing the battery back in and removing the charger and left it for the night. It still doesn't turn on and I'm starting to worry, could anyone help me?
Add a comment
Add your answer
Amanda will be eternally grateful.
Past 24 Hours: 61
Past 7 Days: 570
Past 30 Days: 2,174
All Time: 49,211
