Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
after repair, display is not working anymore
Yesterday, I changed the display/digitizer unit because the original screen showed a grey vertical bar on the left display side. I worked accoring ifixit repair guide.
After reassembling, the display stays black, only the background lighting comes up. Beside this defect, the phone seems to work properly - it is recognized by itunes and i can flash/synchronize.
What I tried:
-I tried to reset (home+power) for several times
-I tried to reinstall firmware (6.2.1)
-I disconnected all non relevant connectors for testing basic function (i only left power button, display and battery)
-I reconnected the old display unit
But nothing helped.
Did I brick my iphone or does anyone have a hint, how to get the display working again? Many thanks in advance!
Score 1
Add a comment
Chosen Solution
You may want to check the miscellanious chips located around the sides of the connector for the LCD/Digitizer assembly. There is a chance that you could have damaged one while lifting up the connector from the old display.
Score 1
Add a comment
Either a damaged chip as stated above or try isopropyl alcohol to clean the connectors as it might have a little water damage
Score 1
Add a comment
Add your answer
ischorsch will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 264
