Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1418 Questions View all
Magsafe and Battery Charger Board serial numbers?
Mackbook 4.1 A1181 early 2008 core 2 duo 2.1 ghz 4gb ram
Hello, I have this laptop and it doesn't seem to work with the battery but it works when plugged in with the charger.
I'd like to replace both the Magsafe and the battery charger board and see if that fixes it (as it wouldn't be so expensive to do both)
But I don't know exactly what part number is compatible with my macbook.
I have these ones booked marked:
Magsafe, 820-1966-A
Battery charger board, 820-2029-A
Is this correct?
Also I've heard that this can also be caused by using a non-OEM charger, and non-OEM battery.
I use both but I have no way of testing it with the original apple products.
I will try if replacing these parts doesn't work and just hope it's not the logic board.
I'd appreciate very much any help. I'm clueless.
Score 1
Comments:
I found that in fact the part numbers I listed aren't for this Macbook.
It's:
Magsafe, 922-8268
Battery charger board, 922-8275
This info was hard to find :/
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Here's the MagSafe board: MacBook MagSafe DC-In Board
The 820-1966-A is for a 2006 black machine. I would replace the board first as you don't seem to have a problem with the charger.
Here's how to replace the board: MacBook Core 2 Duo Magsafe Board Replacement
Score 2
Comments:
ah! thank you very much. just as I added my comment.
by
Add a comment
Add your answer
Bridget will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 35
All Time: 2,166
