2.26 or 2.4 GHz / White plastic unibody enclosure
618 Questions View all
Is my MacBook LCD a match for the replacement on here?
I noticed that on here the tutorial to fixing your Macbook LCD screen was for the one with the plastic bottom. My Macbook does not have that, it has a rubber bottom and I was wondering if the LCD parts are the same as they are on this website.
Comments:
Ian, give your the last three digits of your serial number. this will help us to properly identify your Macbook.
by
Serial No: F5X
Model No: A1342
by
Does that look right:"2.4 GHz Core 2 Duo (P8600)
Intro Date: May 18, 2010 Disc Date: February 8, 2012*
Order No: MC516LL/A Model No: A1342 (EMC 2395*)
Subfamily: Mid-2010 Model ID: MacBook7,1
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 250 GB (5400 RPM) Std Optical: 8X DL "SuperDrive""
by
Yes! Exactly!
by
You sir are a life saver! Thanks a ton!!
by
Show 4 more comments
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Ian, this should the right guide for your MacBook. Hope this helps, good luck.
Score 2
Add a comment
Add your answer
Ian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 230
