Repair guides and support for many cameras in the Coolpix line by Nikon.
702 Questions View all
Question Closed
Nikon Coolpix S230 touch screen doesn't work well
Hellow!
I have NIKON Coolpix S230 camera.
The problem is that the touch screen does`nt work well.
I can not choose the top options on the screen. Example when I press the keys on the right screen to move through the menus, then a question mark button is pressed.
Another example, I can not choose the option to "reset all".
In short, the top of the touch screen does not work. Do I need to replace screen?
Add a comment
1 Answer
Most Helpful Answer
ofirshay1, this behavior is usually caused by a bad digitizer. Just double check all your connection make sure that they are properly seated and check to make sure that there is no tear in any cables. You most likely will have to repair the digitizer. Hope this helps, good luck.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 494
