1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 Questions View all
Question Closed
A coffee disaster and 60 days later, computer is a zombie
So, a coffee disaster happened 60 days ago, the computer needed 0.3 seconds to turn off and say goodbye for ever.
BUT, not for ever, just today it has been turned on and oh-magic it has actually turned on.
Battery is dead, but other than that everything seems ok. BUT not, it is not ok, it is terribly slow.
My question is, how can I know what is causing the problem? I will open it ASAP but there are 2000 km between us right now. I am having access remotely to it. Is there anything I can do to point to what part has been damaged and is causing this very significant decreased velocity?
UPDATE:
So, finally we got the computer back and could open it. I attach the images of what we saw, it did not seem that bad. We used a cleaning spray (also photo attached) to clean the coffee rests, and assembled everything again.
And surprise surprise, speed was back :) Battery was dead but the computer was completely recovered in terms of usability. Pretty surprising giving the fact that the Apple technical service wanted to just replace everything (asking for more money than a new air).
After that, we have ordered a battery from here (this is the only place in the world that you can buy spare parts of macs? If so, you HAVE to open a "shop" in Europe!), and once assembled everything has returned back to normality.
Not necessary to say that we are very happy :)
Thanks all of you for your comments!
Add a comment
Chosen Solution
Try disconnecting the internal hard drive and booting from an external and see if it is still slow. Please let us know your results.
Score 3
Add a comment
The logic board needs to be removed from the machine and cleaned if it's not too late.
Score 3
Add a comment
I agree with lemerise, you need to have the system serviced by a professional. Especially since the system is in a remote location.
That means dis assembly and cleaning all components that have been exposed to the coffee. If it was pure black coffee, it's not that bad, but seriously, if it was coffee with cream and sugar (dries and can cause conductivity between board components) if you keep powering it up it is going to continue to affect components throughout the system until something decides to blow.
If luck is in your favor you shouldn't have problems, however, just a bit of sugary blobs of sweetness somewhere on a board that is overlooked can cause big problems over time.
Keep us posted.
Score 3
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 359
