Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix.
174 Questions View all
Can I get out of Safe Mode after water damage?
Dropped my Nexus 7 (32gb, WiFi, 4.2) in the bath. Removed the back, dried everything out gently over several days, but now it will only boot up in safe mode.
Did factory reset, everything re-loaded, wifi works as can access emails, but cannot access any other post-purchase loaded App because I cannot get it out of Safe Mode.
Are there any suggestions apart from "Buy a new one"?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
It might still be damaged from water, Try taking it fully apart and bathing it in denatured alcohol. Use a some what small paint brush or some other soft brush, Brush everything inside with the alcohol, Should dry vary quickly. Reassemble and try and see if it works correctly.
Let me know how it turns out.
Hope this helps
Comments:
Thanks qpunk, I will give this a go when I acquire the denatured alcohol (and after I take a brave pill!).
I will let you know the result.
M
by
Add a comment
If you are based in the UK there is a company that i used to repair mine, they used some sort of board cleaner to get mine working again and it only cost me 20 quid :)
http://www.repairsuk.co.uk/asus-nexus-7-...
Add a comment
Add your answer
Margaret will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 39
All Time: 1,680
