Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Questions View all
Question Closed
New digitizer won't work
I have an ipad 2 that had a cracked digitizer so I decided to replace it before I gave it to a family member (I didn't bother to read any guides btw) I had that family member find an ipad 2 digitizer off the Internet so that I could replace it. I had never taken apart an ipad before, only an iPhone, so I didn't realize the wifi antenna was at the bottom. After breaking the antenna, I carefully detached the old digitizer and the LCD. After replacing everything, I then realized the digitizer wasn't working. The home button and power button worked of course but I couldn't swipe anywhere on the screen to make the ipad do anything. So I switched the new screen with the old one to see if it was just a defective digitizer. Neither of the digitizers worked. As I was taking the digitizer off the initial time, I didn't see the release flaps for the digitizer, so I ended up carefully pulling the "hook ups" out, so maybe I shredded something somewhere that I can't see. I really hope that's not the problem. I don't know what to do now, besides order a replacement wifi flex cable. I need help bad! Please and thank you!
Add a comment
1 Answer
You probably broke the clips off that hold the digitizer cables in place... One thing you can try to do to hold the cables down is to put some thick (but not too thick) tape or double sided tape with the backing still on it on the tops of the cables. make sure to cut the pieces a little narrower than the cables themselves. Test to see if they then work and if they do then make sure to tape them good into place so the don't come out.
1 Comment:
The clips are fine. Like I said, it's probably the metal part on the underside of the digitizer hook ups, where I can't see it. The problem is, is cant be fixed. That part can't be replaced so I can't put a new screen on it. My only option now is probably sell the ipad for parts, but I don't know how or where. Any suggestions?
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 783
