Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1497 Questions View all
Home button is fine but the iPhone does not "sense" it...
I have this iPhone 3G, it fell in the water and incredibly, it is working fine.
Only one major issue: the home button. I know it does work, cause I swapped the whole screen with another iPhone 3G. On the other iPhone the home button works.
So I guess the problem must be on the motherboard.
Any suggestion?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
Marco Rotini, the very first thing with any water damage, should be to clean it to prevent corrosion. The guide to use is this one. I suggest you do not deviate to much from it, avoid acetones etc. since they can dissolve some plastics. Check all your connectors for corrosion, debris and bend or broken pins. Also check for missing and/or obviously damaged components. Hope this helps, good luck.
Score 1
Add a comment
Hi,
this can be a problem with the flex cable on the top of the speaker, there are the contacts for the home button or with the conncetor the connects the speaker,dock,home button to the logic board. First try to clean the connector with acetone and the try again...
Add a comment
Add your answer
Marco Rotini will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 155
