Model A1200 with 2.16 or 2.33 GHz Core 2 Duo processor
113 Questions View all
Question Closed
1/4 inch Audio Output broken on 2.16GHz iMac
The "possibly Related Question" is not my problem. Due to much use since new, the Audio Output female connector on my iMac24 has finally refused my desires to transmit just this one last time before fixing. The audio out signal is still slightly, but only occasionally there, but the male connector from my recorder simply won't carry the iMac's AUDIO OUTPUT signal. And, I know the problem is right inside the iMac's back cover. What I need to know is: What comes off first, and last, so I can repair the board/connections/female jack to put me back into my one-armed (no laughs) repair job. I have many years of electronic (not just electrical) training so I know I don't want to break my original iMac 24 due to ignorance. It feels like a connection has broken loose from a trace as I can still get a lousy output signal if I hold things just right. Thanks for helping me get this thing opened so I can get to the break. Take a break; thanks!
1 Comment
There was no 2008 2.16 machine. There is a 2006. Please give us the last three figures of your serial number (located on the bottom of the stand).
by
Add a comment
1 Answer
Chosen Solution
Easiest DIY workaround: Get a USB Audio Adaptor - it will have the port you want, USB audio is separate from logic board audio.
The third line at the top of the Mac device repair page: properly ID your Mac . . . If you can't do that basic step the chance of you soldering/tinkering the logic board without breaking it, IMnsHO, is slim.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 185
