Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Question Closed
Can't upgrade to Snow Leopard from 10.5.8
Hello, I know this a bit outdated...
I have a black Macbook Core 2 Duo 2.2. Ghz 13" S (Santa Rosa). I love it, I've had it for years and it's always done me well. About a year ago the DVD drive started giving me trouble (not sure if this is common, but I've heard others say the same) but I wasn't too concerned as I rarely use it.
A friend's now loaned me the Snow Leopard Install DVD to upgrade my OS as a lot of applications are no longer compatible, but my computer seems unwilling to take it!
Out of the variety of problems I've encountered it has:
1. Been "unable to read the disc" and asked if want to cancel or eject
2. Been "unable to install from this volume"
3. Gets stuck at "49 minutes remaining" and when I reboot it simply spits the disc out
4. It will not boot from the disc either, it simply just spits if out even if I hold Option while booting.
I'm currently in the process of making a .dmg on my work computer so I can try to boot from a partitioned HD, but does anyone have any similar experience with this? Should I simply learn to love 10.5.8??
Any help or similar experiences appreciated!
1 Comment
Apple MacBook "Core 2 Duo" 2.2 13" (Black-SR) Specs
Identifiers: Late 2007 - MB063LL/B - MacBook3,1 - A1181 - 2200
by
Add a comment
1 Answer
Chosen Solution
If you are trying to use a gray system installation disk, those are machine model specific. If trying to install from a retail disk your optical dive sounds bad. Use a similar Mac from about the same era, put it into Target Mode via a firewire cable and start up your machine while holding down the "T" key. Your hard drive icon should now appear on the other machines desktop. Now use the optical drive on the working Mac to install a system onto your machine. Be aware that it will install a system suited for the machine that is reading the disk, so if booted say from an iMac you wouldn't get some of the utilities used on the laptop. That why it's better to use a Mac close to the same age.
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,022
