Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3236 Questions View all
Dim Screen After Proximity Sensor Replacement?
So, I changed the proximity sensor on my iphone 4 (at&t) and it seemed to go well. However, once I got everything back into place I found that my screen was dim (back light only), very frustrating. Here are the symptoms:
1. It seems everything is still working although I can not see the screen (i.e. can still make calls using voice commands, can hear incoming calls although can not accept since I can not control the screen)
2. I've tested two other screens and neither of them worked. However, the two other screens flash bright white when activated.
3. When replacing the power button bracket I found I had to leave the two screws unscrewed by about a full rotation to allow the power button to "click"
I've tried a hard reset, no dice. I'm letting the battery fully drain as we speak.
Any suggestions on what the problem may be?
Thanks a lot for your help
Score 1
Add a comment
1 Answer
Chosen Solution
Good (and bad news)!
So, unfortunately after letting the battery die the screen did not miraculously come to life as I hoped it would. I thought for sure I fried my "6r8" coil (I dont really know what that is) and was preparing to take the phone in to get professionally worked on. However, just to be sure, I tried my old screen one.. last... time... VOILA! The hard reset/battery drain must have worked for them! So I must have been too rough on the cables when installing the power button and torn something.
Score 2
Comments:
Great job. All you have to do now is to accept this answer. That way everyone looking for an answer to this problem will know what worked. Again, great job.
by
Add a comment
Add your answer
Birdman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 317
