Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3232 Questions View all
What did I do wrong?
Hello, well I have an iphone 4 att 16 gb. The home button wasn't working on it so I decided to replace it and all. It was successfully but something went wrong. As I was putting in the battery back in the end to "test" out the iphone. The little plastic flap with the hazard sign was stuck folded back and I forgot to unfold it when I put the battery back. So I decieded to pull the battery out again. I was gently going to open the battery tab to disconnect the battery and for some reason, the battery tab came out.
Now I thought, oh well if I at least put it back into position the battery tab, it would fit in and be sort of "fixed". I plugged in my iphone to the wallcharger, it turned on my iphone and suddenly the ios 6 sign comes on... I use an iPhone 4S now so I haven't really updated this one that I was fixing. Afterwards, I slide to open bar on the ios 6 screen and then the next screen has the "connect to iTunes" image. So I do that, but after I disconnect my iphone 4 from the USB cord, the iphone shuts off. Weird I though and then I connect it iTunes in my computer, but now my iphone keeps turning on with the apple logo then off like less 5 seconds repeatably. This was my 4th time opening up my iphone 4, but now this thing happened I don't what to do really.
Add a comment
1 Answer
Chosen Solution
Your iPhone boot and reboot indefinitely because it does not recognize the battery. Try to disconnect the battery ...you will see same problem.
Battery connector on logic board is ok ?
if yes try with a new battery
Add a comment
Add your answer
manueljrojas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 170
