Support for the third generation of Chrysler Town & Country spanning model years 1996-2000.
7 Questions View all
Change rate of turn signal on 2000 Chrysler Town and Country?
The left front turn signal blinks very fast. How can i change the front left turn signal bulb on my 2000 Chrysler town and country?
Add a comment
Chosen Solution
Rachel San Miguel, the bulb that needs to be changed is not the one that flashes fast :-) The fast blinking is usually an indicator that one of the bulbs is burned out. Check the rear indicator light bulb and cable connector. Make sure the bulb is properly seated. Hope this helps, good luck.
Score 2
Improper bulbs for example some led bulbs can cause this as well
Add a comment
Most Helpful Answer
This should help you.
If you need help finding the part, here you are:
The part isn't guaranteed to be the right one, since I don't know the specific edition of your vehicle, but it should be close enough. Best of luck.
Score 2
Add a comment
Add your answer
Rachel San Miguel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,172
