Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
702 Questions View all
MBP A1278 Error 4SNS/1/c0000008: TsOP--124
I have a MBP 2011 13 A1278 cannot find the left palm rest sensor????
err 4SNS/1/c0000008: TsOP--124
PLEASE HELP!!!! TY
Comments:
Please tell us the last 4 charaters of your serial number, so we can determine your exact machine. Also, please tell us more about your problem, what your MacBook is doing or not doing.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Ts0P = Trackpad flex cable
I think you have to look a bit deeper here. I suspect something was spilled into the keyboard/trackpad causing it to error out here. If you're sure the sensor is gone you'll need to replace the trackpad flex cable.
I would also install a good temperature monitor app like: Temperature Gauge Pro to better monitor the sensors.
Score 2
Comments:
I had the same problem and I got a replacement ribbon flex cable (connecting the trackpad to the logic board). The problem is solved. Thanks a lot.
by
Add a comment
I have the same error code;
Symptoms;
Fan runs at max speed all the time,
In normal boot, kernel_task is taking over 100% CPU
In safe boot , problem is gone.
If ioplatformplugins kext/ahci SMC profile for MBP 8,1 is removed (the model of my crapbook) the computer runs normal, but the fans are at max speed.
I need location of sensor (palm sensor) which I believe is under trackpad, because I refuse to pay crApple $600 to herp the derp.
Thanks guys!!
Comments:
Your systems specs: MacBookPro8,3 - MacBook Pro 17" (Late 2011)
by
You'll need to follow this guide: MacBook Pro 15" Unibody Late 2011 Trackpad Replacement as we don't have one explicitly for the 17" model.
by
Add a comment
Add your answer
jwills1 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 2,428
