Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Question Closed
Can my MacBook Pro 13 use hard disk 7200rpm?
I have a MacBook Pro 13. my hard disk speed is 5400 rpm. so should i change my hard disk speed to 7200rpm
Add a comment
Chosen Solution
I prefer the 7200 rpm Western Digital Scorpio Black 320 GB. I use 2-3 a week for my customers and have never had a problem with one of them.
Score 4
3 Comments:
There used to be a problem with heat generation with the faster drives, back in the dreaded iBook days. No issue here anymore?
by
I haven't seen heat problems with hard drives in years.
by
+ There should be no heat problems. Depending on your energy saver settings you may see less battery life. On the plus you will have a faster machine.
by
Add a comment
I installed a 7200 rpm WD Scorpio Black 320GB hard drive into my MBP13 in January 2010. I have had no problems whatsoever with this upgrade. There has been a bit more heat evolved, but the aluminum unibody dissipates heat very effectively. No noted changes in noise, vibration, power consumption.
Update (05/02/2010)
Installed a Crucial 500GB SSD in my MBP13. They are much cheaper than when I put in the Scorpio. Additionally, much cooler, faster, longer battery life. YMMV.
Score 2
2 Comments:
I can also recommend the 7200 rpm WD Scorpio Black 320GB hard drive. Got one that I installed two years ago and no problem with it.
by
Yup, keep in mind that battery life may go down.
by
Add a comment
Score 1
Add a comment
I also used a WD Scorpio in the same set up. It was a little quicker, but I keep my MBP on my night stand and the noise was a little intrusive. It got a little warm and power hungry and I am buy no means someone who stresses their computer. My only excuse for upgrades is curiosity. Yes, put a 256 Crucial SSD in, but couldn't bear the waste. I settled on an 80.
My suggestion, MCE Optibay, 60-80 GB for OS and apps. A nice power friendly 500-1000 for your less intensive apps and media.
Apple is becoming Microsoft I'm afraid. And I,ve been evangelising for 10 years, and I'm starting to feel less is more.
I,m bound to itunes, but Chromium and Splash....? are my next points of interest.
Add a comment
I use Mac Book Black 2.o Ghz. I want change new HDD and I want to know I can use 500 Gb 7200rpm ? Anyone who knows please help me solve this problem.
1 Comment:
Of course you can. If you have further questions on this please start a new question.
by
Add a comment
I also have an MacBook Pro 13" mid 2009, and I've just put in a WD 7200 rpm 750GB and I'm having trouble installing. Is 750GB to big??
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 8,741
