Weller Soldering iPhone Question
Hi guys I am a first time poster but a long time viewer. I just purchased a Weller WM120 because of the low watts(12 watt) and the pencil thin tip to work on iphones Well I am in the process of repairing the battery connector back onto the motherboard. I purchased a 60/40 rosin core soldering wire that is .06 inches thick so I assumed that would be small enough but come to find out when I hold the tip of the weller to the solder it will not do anything. The only way to get it to do something is if I place the wire on the side of the tip. Sooo should I purchase another soldering iron with a stronger wattage or did I get the wrong type of soldering wire. I am very new to soldering so I really could use any advise.
Thanks in advance guys!
