Model A1320 / 8 or 16 GB capacity
154 Questions View all
Question Closed
What if it is not getting on, not charging and also overheating?
firstly my iPod's camera stopped working then suddenly my iPod also.....i have tried to reset it but failed....it does not sync or charge further it got over heated both charger and iPod please guide.
Add a comment
1 Answer
Chosen Solution
aman, the overheating can be caused by a bad battery as well as a bad power management IC. Either case, you would have to disassemble your iPod. Use this guide to change your battery. It is a bit of a PITA to work on it, but can be done. Once you replace the battery, re-evaluate and see what you got. Make sure that the dock connector is clean, and that it does not have any bend or broken pins. Hope this helps, good luck.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 867
