Can I replace the hard drive on my iMac 2007
I have a 2007 20-inch iMac that I use to archive photos and music. I am constantly running out of space. Can I / how do I upgrade the hard drive?
Hi, Click on the following link and select your iMac. You would then select the guide for replacing the hard drve. Please read it all the way through several times to make sure you understand what tools, parts and skill you will need to make the change. If you read carefully and go slowly you should have no problem. Good luck.
If your computer is a 2007 model this is probably the guide you need but check the numbers to be sure.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,163
1 Comment
It would help to have a model number and such, any details would be appreciated. Its generally not that hard to replace HDD's inside of an iMac it's just requiring a few tools you may or may not have. Also if you provide more details we can send you to the right guide and give you more information.
by flogo2003
