1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
256 Questions View all
Can I upgrade the processer?
I have a iMac intel core 2 duo 17" and I was wondering if I could upgrade to an i3, i5, or i7
running osx 10.7.5
Comments:
would it be possible?
by
please respond
by
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Your machine:http://www.everymac.com/systems/apple/im...
has the T7200 processor with an "M" socket: http://en.wikipedia.org/wiki/Socket_M
Replace with any of these: T5200, T5300, T5450, T5470, T5500, T5600, T7200, T7400, T7600[
Here's my post with links on upgrading the CPU: change MacBook Pro cpu from core duo to core 2 duo...
The 2.16 GHz is a T7400, M socket. You can probably take it to a 2.4 GHz T7600, M socket.
Score 2
Comments:
what is the t7600?
by
would it be able to work with an i3?
by
Ted you have a fine last name but you're a lazy boy. Learn to use Google. You will not be able to upgrade to i3 processor.
by
+ Mayor is correct on the best processor you will be able to install on this. The C2D and iCore processors require different sockets and architecture.
by
Add a comment
Add your answer
Ted Mayer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 383
