Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
My iPhone 3G does not turn on?
I charge it last night then when I woke up the phone is so very hot then I try to open, its not working it does not turn on.
I try the "by holding down the sleep/wake button and home button simultaneously" but it does not work too.
What did I do? :( Help me PLEASE. :( I would appreciate any suggestion/solution pertaining to this problem.
Add a comment
1 Answer
Chosen Solution
lruelja, the very first thing I would do after the steps you already did, is to replace the battery. It is possible that your battery is heating due to its inability to hold a charge. Use this guide to work on it. Start with that. Hope this helps, good luck.
thank you so much. :D i'll try it. :)
Add a comment
Add your answer
lruelja will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 313
