Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3282 Questions View all
How to put back on front camera retainer?
Does anyone have any advice on how best to put back on the front camera retainer in an iPhone 4 & 4S? It is quite hard to get all 3 clips engaged. I usually settle for only 2 when putting this piece back, but it makes the front camera not centered.
Thanks!
Add a comment
Android Fix Kits
A new screen or battery is one kit away.
Shop Now
Android Fix Kits
Shop Now
Chosen Solution
I normally use a pair of tweezers. Start with the right side first, then the bottom and then the top. You have to make sure the retainer clips go on the outside of the points where they attach. But you are right, this is a very difficult thing to get back in to place. Good luck!
Score 6
Add a comment
I fought with this for a long time and thought I had ruined the clip. Then I stumbled upon your great description and realized I had been trying to get the clips to fit on the inside of the brackets instead of the outside! I though I had ruined the clips legs until I read your post. Thank you.
Score 1
Add a comment
Add your answer
Chad Silverman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,070
