Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
295 Questions View all
Small scratch on the digitizer - low half (1 cm) not responsing
After replacing my ipad 2 broken screen, about 1 cm from the bottom of the touch is not responsing. The rest of the Ipad touch screen is working. I found a a small scratch on the digitizer screen. Would that be the problem?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
peckha, I am sure it is not the scratch that gives you problems, but it is most likely indicative of a fractured digitizer circuit. This happens actually quite frequently. I would suggest that you contact the vendor and have the digitizer replaced. Hope this helps, good luck.
Score 2
Comments:
Thanks for the answer. I mis-spoke about the scratch. I found a small tiny scratch on the LCD screen. Would you think that is the problem?
by
Same problem. If there is a certain area that is unresponsive to touch it is most likely a bad circuit.
by
I appreciate the response. Thank you. I have put a request for replacement and return.
by
It is not the scratch on the LCD that causes your digitizer to have failed :-)
by
Add a comment
Add your answer
peckha will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 873
