Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
11 Questions View all
Can you cut one set of wires?
My floor lamp has five arms resulting in 10 wires, can I cut one set of wires and cap (one arm has faulty base)?
Add a comment
Chosen Solution
Yes but you must cap/insulate each end of the pair you cut.
If this Answer is helpful please remember to return and mark it Accepted.
Score 2
Add a comment
I can confirm previous answer.Its not necessary but if possible also is good to check for grounding,or short circuit..
Add a comment
Add your answer
fay kivela will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 236
