13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
587 Questions View all
black plastic between de screen and the keyboard?
I want to change that black plastic peace in the outside of my mac between the LCD and the keyboard, Where can i find it???
Comments:
Thanks!! I was talking about the hinge clutch cover! Is that piece for an macbook late 2008?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
It's not sold as a separate piece. It comes with a top case replacement. I haven't found what material it's made of, but if you did you could use the old one as a template. It's got to be some kind of heat resistant plastic.
Score 1
Comments:
See step #26 of this guide for removing the clutch cover: MacBook Unibody Model A1278 LVDS Display Cable Replacement
by
Add a comment
Hi,
Are you referring to the front lcd glass/ bezel cover: http://www.ebay.com.sg/itm/New-Apple-MAC...
This one listed on ebay cost around $28USD (brand new). Replacing it aint easy as it is held on by glue which you'll need a heat gun to soften the glue. Plus a lot of strength! >.<
If it is the hinge clutch cover: http://www.ebay.com.sg/itm/Macbook-Unibo...
This one is listed on ebay for about $16USD.
Replacing this is very easy.
Score 1
Comments:
by
Hi i found this on ebay: http://item.mobileweb.ebay.com.sg/viewit...
Im not sure whats your exact model but this one above is for model A1260. Do verify before buying. Hope it helps! :)
by
Add a comment
Add your answer
goncalopinho will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 626
