Why is newly installed internal HD not seen by Utility Disk?
Although all connections have been checked on this Western Digital 250GO IDE drive
Add a comment
Free Shipping on all orders $79.00 and up.
Browse Our Store
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Chosen Solution
Need history, why was the drive replaced, was this a new drive? Try formatting it using Disk Utilities on the second page pull down menu from Utilities.
Score 2
Comments:
It is a new drive, in replacement of an older one that had gone bust.
The problem is I can't even begin to format it, as its name doesn't appear in the list of the Mac OS installer. I hear (and read) that I need to use a hard drive external case enclosure to format it before I can put it back in. Does that hold water?
by
The drive should format internally. First, did you get it from a good source? It needs no jumpers so if some are present, remove them. When you say the old drive "went bust" what happened? Were you able to see it?
by
The new drive is a brand new Western Digital bought from MacWay (France), so no problem from that quarter. No jumpers are present. What actually happened was a fall from a low table, when the Mac was on, after which the drive went tap-tap-tap-tap at regular intervals on startup, with the wheel going round nonstop.
Many thanks, mayer, for going to the trouble of answering me.
P.
by
The drive should be seen when installed internally. There may be a 128 MEG limit since this is a G4. That means your G4 may only see 128 MB of the drive. To get a full format of the drive it needs to be formatted into two partitions. This can be done in an external enclosure or an adapter. The adapter will work on both IDE and SATA drives. The enclosure can be used as a backup unit or for storage.
Here's a link to a great little adapter that I use: http://eshop.macsales.com/item/Newer%20T...
Here's an enclosure: Firewire ATA Laptop Hard Drive Enclosure
If you do go with an enclosure, do the firewire rather than a USB. You can boot from an external firewire but not a USB.
by
Add a comment
If its' not misaligned ATA pins
... it could be that the ribbon cable has been damaged or the connector on the bottom of the logic board is broken or loose, I have seen either of these happen.
Good Luck,
N.
Score 1
Add a comment
Add your answer
Patrick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 673
