Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
3gs not turn on,charged and recognize by itune
I've replace the battery (new battery has 3.7V) and dock connector assembly, but with no luck. Iphone still not turn on, no battery sign when connected to charge adapter, and still not recognize by PC.
All connectors seems attach to the board pins properly.
2 Comments
How long has this been going on? Did anything happen to the phone? Did it get water damaged or did it get dropped? When you say you replaced the dock connector assembly, how did you do that?
by
I never use the iphone for almost 2 weeks.
It never dropped or get water damaged. I replaced the dock connector by taking all the assembly and replace with the new one I bought thru ebay.
by
Add a comment
Chosen Solution
Rudita, here is a bit of an idea about the voltages on your motherboard. Let us know what you find.
Score 1
Add a comment
I think your motherboard would have short circuited.
Why don't you check it using a multimeter?
1 Comment:
How to tell if the motherboard is short circuited. I have multimeter but I don't know how to check the motherboard.
by
Add a comment
Add your answer
rudita will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 242
