Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3252 Questions View all
After Front Panel replacement, speakers, Dock and Mic don't work
Hi guys,
I just successfully replaced the front panel of my iPhone cause the glad was Brocken and touch didn't work.
After I reassembled the phone, everything was working except the laud speakers, mic, dock connector(no charging available anymore).
What could be the reason? Which part connects these elements to motherboard.
I also don't get how the mic(bottom black part) is connected. As far as I remember it has just one cable that connects with motherboard - that's the antena cable, but what with the rest?
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Hi
The issue is maybe 2 things
The mic connector at the bottom (the balc with the antenna cable) you will notice has 4 metal prongs, these need to be tucked in underneath the metal midframe, if they sit on top you may get the issues you are describing
if these 4 prongs are correct then the fault is likely to be with the cable that feeds these things not being on properley, this is the cable that has the little black metal plate with the 2 screws.
Ensure this cable is down properly
i provide a link to a video that may help
http://www.youtube.com/watch?v=QRSvswPGl...
At about 2:43 you will see the metal plate and cable i am referring to
Regards
Ali
Add a comment
Add your answer
Tom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 265
