Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1497 Questions View all
after LCD relacement, the iPhone doesnt work.
Hi.
I need help very fast, its the iPhone of my sister :-(
I replaced the LCD. I worked with a tutorial and now, the iPhone doesnt turn on.
what should i do???
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
This is somewhat common. It's usually a cable that's not plugged in all the way. Check out the answers to Why is my screen is black after replacing the lcd and digitalizer? and Replaced Lcd Screen and it doesnt respond at all
Score 1
Comments:
Thank you. I could fix that Problem, but now, the iPhone doesnt start up. The Apple appears, and then the screen goes white.
When I reset the Phone with the DFU mode, it works fine until it restarts after the reseting. Then, the screen also goes white.
Is there any solution for that problem?
by
Add a comment
did you ever fix it, and if so how??im having the same issue
Comments:
check your battery connections. this is the most likely culprit for apple logo cycling on and off-not enough power to boot to home screen. check pins aren't flattened and are in good contact with motherboard, clean all connections with isopropyl alcohol and a soft brush to remove any dirt that might have got in when you opened the phone.
if this doesn't work you need to start your own question... and give lots of history about why you replaced the screen and how..
by
Add a comment
Not really.
I know, that the company in switzerland which "repairs" all the handys (its one company for whole CH) is not allowed to open up the iPhone. (i think it may be the same in other countries, they only look if the glass is broken or if the water indicator is red)
So i put it together and brought it to the swisscom store for a warranty check. They've sent me a new one.
So, i've lied a bit but who cares? ;-)
I think i had the issue because of an electrostatic discharge. I'm an electronician and i know from my work, how dangerous this ESD is for the electronics. My mistake was, to do it at home and not on my workingplace, which is ESD protected with special shoes, wrist band etc.
Add a comment
Add your answer
Dominic will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 5,398
