F02 code, tube is not cloged, frozen or too high. What next?
Recieved the F02 error code. I removed the tube a nd flushed it. A small amount of gunk came out be it was not clogged. The drain hose & tube are on an inside wall and have a shared drain pipe with a sink that continues to drain fine. I replaced the drain hose and still get the error code. Machine no will not "run" and has standing water in the drum. Anyone run into this and figure it out? Thank you in advance.
