Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
944 Questions View all
I replaced the logic board, and the click wheel shuts it off.
After replacing the logic board (with the guide), now every time I use the click button, or switch the hold switch, it shuts off the ipod.
Add a comment
1 Answer
Chosen Solution
sonicsean89, double check your connectors and make sure the locking tab's are down and that the cables are in straight and are properly seated. Sounds like it is shortening out. IF nothing else, replace the click wheel. If you still have problems with it, contact the vendor and see if you can get the logic board replaced Hope this helps, good luck
Score 1
Add a comment
Add your answer
sonicsean89 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 136
