Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
19981 Questions View all
Question Closed
My MacBook Pro won't power up
Hi first of all thanks a lot for for any of the help you may give me. I tried changing my hardrive which I believe I did successfully problem is as since its been installed my computer died. It doesn't switch on even with the charger in its crazy it was working perfectly fine before and I've tried installing a different hard drive but still nothing.
4 Comments
Ah just noticed the light on the charger comes on feintly but still doesn't switch on
by
Peter Czechowski, what are the last three digits of your serial number? This will help to identify your MBP.
by
ATm, I've tried leaving it to charge overnight didn't work I've tried hard resetting the smc I just don't understand it:(
by
Add a comment
1 Answer
Chosen Solution
Double check all your connections... if you have a loose ribbon cable or \ connector it would cause the non-start issue. You might try bypassing the power button to eliminate the logic board as the cause.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
1 Comment:
i really don't understand where he is talking about i've looked on youtube but the place they're talking about doesn't exist on my laptop. either way i don't think its my keyboard otherwise there wouldn't be a dim light on my carve cable surely? i still can't see it being the logic board either considering it was after a hard drive update it didn't just happen out of no where
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 492
