Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Questions View all
Question Closed
Fan Shakes, Magsafe LED is on and than it turns off slowly
I have a new tested Logic board in my macbook, but it doesn't work.
When i plug in the Magsafe charger the Green LED turns on, than the fan shakes a little bit but nothing when I press the Power button. After a few moments the LED of the Magsafe cord slowly dims down to off.
Can anybody help me?
Update
When i make it with and without battery it is the same.
Without battery it is how i have discribed it.
With the Battery it shakes when i press the power button.
Update
Nothing... The cables are all conected... but nothing....
Update
The old one was damaged by a Latte Macchiato... not by me, but I have become the trash and now i try to get a working LogicBord.
I try another one.
Thank you for your help.
Update
Nothing get wet only the magsafe and the logicboard.
The magsafe is replaced.
3 Comments
Do you have the battery plugged in? If you do, try testing it with out it. What happens then?
by
Are you sure the logic board is good? What happened with the old one?
by
It's possible you have other problems with the other parts of the system.
Did you clean everything down where the drink spilled into? How is the keyboard? Did it get wet?
by
Add a comment
1 Answer
Chosen Solution
Try resetting the SMC. If that fails do it again this time holding down the power button for a good 30 secs.
If that doesn't help then you'll need to check your logic board connections did you mis connect one of the cords or ribbon cables?
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 272
