My rMBP is a bit quirky when charging.
Back Story: About a month or two ago I spilled water on my rMBP and I immediately turned it off and let it dry for several days, when I turned it back on to my horror I found that it would not hold a charge. I could turn it on and it would tell me "plugged in, not charging", but even with that it would turn off after about 5 minutes of usage. I came back home from University and basically ignored my laptop for about a month (I used my desktop). I shipped my desktop off to University a couple days ago and decided to see if there was any change in my laptops state. To my surprise it will now hold a charge! I've been using it the last two days without any real problem (besides what I'm about to explain).
The Problem: The laptop WILL charge now but only under certain circumstances. Basically I can only charge in increments of 1-2 hours at a time, keeping the magsafe 2 adapter in for any longer will switch it to "plugged in not charging" even if it isn't at 100%. If I take the charger out and immediately plug it back in it is a no-go. I have to wait at least 30 minutes before charging again. I was hoping that there might be a (under $200) solution to fixing this small quirk? I can live with this defect but I would prefer not to. I have Apple care but told apple about the water and they've basically black-listed me from any help at this point. (I have done a pram/smc reset).
Power Information:
Battery Information:
Model Information:
Serial Number: (hidden)
Manufacturer: SMP
Device Name: (hidden)
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 511
Hardware Revision: 3
Cell Revision: 1150
Charge Information:
Charge Remaining (mAh): 5040
Fully Charged: No
Charging: Yes
Full Charge Capacity (mAh): 8028
Health Information:
Cycle Count: 160
Condition: Normal
Battery Installed: Yes
Amperage (mA): -284
Voltage (mV): 11644
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Wake on AC Change: No
Wake on Clamshell Open: Yes
Wake on LAN: Yes
AutoPowerOff Delay: 14400
AutoPowerOff Enabled: 1
Current Power Source: Yes
DarkWakeBackgroundTasks: 1
Display Sleep Uses Dim: Yes
GPUSwitch: 2
PrioritizeNetworkReachabilityOverSleep: 0
Standby Delay: 4200
Standby Enabled: 1
Battery Power:
Display Sleep Timer (Minutes): 2
DarkWakeBackgroundTasks: 0
GPUSwitch: 2
Reduce Brightness: Yes
Standby Delay: 4200
Standby Enabled: 1
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Wattage (W): 85
Family: (hidden)
Charging: Yes
