Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1497 Questions View all
home button works sometimes and sometimes it don't?
why does my home button work sometimes then sometimes it don't?
Add a comment
1 Answer
Chosen Solution
Try this, Step 1: Navigate to, and launch one of the stock applications on your iPhone. If you don’t already know, the stock apps are things like weather, YouTube, stocks, settings etc (any that come as part of iOS).
Step 2: When the app is launched, press and hold the Power button located at the top of the device until the ‘Slide to power off’ appears.
Step 3: Press and hold the iPhone home button. Keep the button depressed until the Slide to power off slider disappears and the application quits back to Springboard.
Step 4: Voila! Your home button is now re-calibrated and should be more responsive for you,,,if this doesn't fix it you will need to replace the home button and flex ribbon, good luck, , If this Answer is helpful please remember to return and mark it Accepted.
Add a comment
Add your answer
jordan williams will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 209
