Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
White Display w/ Vertical Stripes - Got Wet, Logic OK - LCD?
My iPhone 3G had an unfortunate meeting with a puddle. After drying in dessicant for two weeks, I only have a white display with vertical striping, like a bar code. All logic board functions seem to work fine, even the touch, I can turn it off by swiping where the power off slider should be. I also pulled it down completely to check for corrosion at the logic board, all seems clear under the magnifying glass. From what I've read on these FAQ's, I should only need the replacement LCD. Does anyone with more experiance concur?
Thanks,
Matt
Score 1
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Installed my new LCD display tonight, all is well. Thanks to you iFix(ed)it!!!
Score 2
Add a comment
Add your answer
Matt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,253
