Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
308 Questions View all
Antenna ripped in half; will it still work?
When replacing the digitizer I ripped the antenna near the home button in half. I still have it and pieced it back together with the adhesive backing and put it back in place. Before I put it back together, will the Wi-Fi signal still be as strong? When I hit the power button I still have a full signal. Thanks for answering!!!
Add a comment
1 Answer
Chosen Solution
No, it will work if you are next to a router, don't think you are the only one that has done this, I wont open an ipad 2 without a new pwr volume control cable and a wifi cable, it's real tough to remove the digitizer without this happening, good luck, If this Answer is helpful please remember to return and mark it Accepted.
Score 2
Comments:
Thanks for the timely response, Mitch! Ordered the parts after reading your answer and am taking your advice. Better safe than sorry! Thanks again!
by
Add a comment
Add your answer
Cole McMahan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 600
