Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Questions View all
Question Closed
re: Power Ribbon Cable
I have had an ongoing nightmare which started out as a digitizer replacement that ended with tearing the Power Mute Volume cable. I ordered what I was told was the correct part for the PMV cable however as you can see by the associated pictures of Figure A the ribbon does not continue back to Power control board nearest the power button. Figure B shows a working iPad 2 with the same model number of A1395 . You can visually see the difference between the two cables..
[[IMG]http://i1125.photobucket.com/albums/l600...[/IMG]|iPad 2 A1395]
Now for my question
1/ Is there more then one PMV cable for the iPad2 A1395 ?
2/ What if anything is missing from the iPad to make it power on?
Any and all help would be greatly appreciated. I got frustrated and had it sent away to a company that works on iPads. They told me among other things I need a new Power Control Board ?
Thanks,
Chris
Add a comment
1 Answer
Chosen Solution
new2usedcomputers, take a look at this answer, you may just have one of those "hybrids" :-) Hope this helps.
Score 1
2 Comments:
Thank you oldturkey03.. I suspected that I had the wrong part. I am in the process of trying to find the right part.
by
My parts suppliers have this cable listed as 2 options, as pre 2012 or not, https://www.gounlock.com/details.php?ite...
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,300
