screen not working! help!
When i turn my sony cyber-shot DSC-W55 camera on the screen stays black and the word access appears, i cannot do anything with the camera (take a photo, view photos etc) and when i press the shutter button it says please turn power off and then on againg which i have done several times and this has not worked!! HELP???
4 Comments
Thanks for the advice i have tried all of these options and it still says access on the screen!! Any other idea's? The camera is a work camera and were lost without it need it fixed asap :(
by Jodie
Jodie, it sounds like you camera thinks it is plugged in. Have you tried to attach it to a computer and see if it connects properly? Any bend broken or corroded pins?
by oldturkey03
Thanks, but i have looked and can't see any bent or broken pins on the camera or usb cable so i don't think it is that! The camera recognises when it is plugged in and the screen changes to mass usb storage instead of access and goes back to access when i unplug it! I don't know if this means anything but there is a small light above the screen which usually flashes green but is flashing orange at the minute?? I really don't wana write the camera off without trying everything so any idea's would be greatly appreciated :)
by Jodie
the flashing light is your "Access LCD" Check the fuses on the board SY143, that is the board where the memory stick connector is soldered to. There are two fuses of them. Also, check connector CN702. That is the one where the multi-connector attaches to. If nothing else I would probably start with MC-181 FLEXIBLE BOARD
by oldturkey03
