Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2921 Questions View all
iPhone 4s won't charge
Hi!
I have a iPhone 4s that took a swim. Everything seems to be working perfectly, except it wont charge.
I have replaced the dock-connector and the battery, but nothing has turned out working. The battery percentage keeps dropping as i write.
The charging symbol shows when the cable is plugged, but the phone doesn't charge. It is not recognized by itunes either.
However, if i plug the phone into a speaker-dock, music starts playing (from the dock). The microphone, loudspeaker and homebutton is working aswell, so i cant really figure out what the problem is. Is there any other parts i should try to replace?`or is there any other method i should try?
Any suggestions are welcome! i really need this to be fixed
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Most Helpful Answer
You need to disassemble your phone and treat the logic board for water damage, here is a guide for treatment on a 3G but use these methods on your 4,Repairing iPhone Liquid Damage and here is a guide to teardown your 4, iPhone 4S Teardown, good luck, If this Answer is helpful please remember to return and mark it Accepted.
iPhone Image
Guide
Difficulty: Difficult1 - 2 hours
iPhone 4S Image
Guide
iPhone 4S Teardown
Difficulty: Moderate
Score 1
Add a comment
Add your answer
Iver will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,704
