Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
295 Questions View all
After Screen/digitizer Replacement, the power button is not working.
Hello all..
This is my first post, so kid gloves please.
I did the research first before carrying out this task, ie making note of where cables are etc....
My ipad2 for some reason is not like the others for instance, the power cable (top right section) is not visable (I have pictures if needed) all other cables are where they should be.
Now i've checked the cables and re-seated twice and tested the ipad2 and it all works apart from the power cable. Wifi good, sound up n down working, mute working, sleep/home button working.
Now the ipad2 was off before I started and it never came on when i was removing the old screen.
I had to plug the usb recharge cable in to find out that the power button was not working.
I have discharged the battery, still not working.
So is there someone out there that might give me any pointers as to what is going on?
Do i have a faulty digitizer? any suggestions no matter how odd ball it may seem are welcome....yeah yeah No jokers. :))
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Ken your Ipad doesn't look the same in the upper right corner because the ribbon cable you cant find of got ripped out when you removed the cracked Digitizer and that's why the power button isn't working, I figure that cable and the wifi cable into every price quote in my shop because it usually gets destroyed, so its an easy fix, get a new cable and install it, good luck, f this answer was helpful please remember to mark it accepted.'
Score 1
Comments:
Hi, That was my first thought. I checked all the bits of screen and no cable to be found. due to the nature of the break I had lots of bits and was able to view each section of broken glass as it came off so I'm going with My ipad has the ipad 3 power/flex cable.
Apple must of found the error of their ways when it came to flex cables.
Thank you Mitch that is a great comment, one that may of very well been the answer.
by
Add a comment
The cable that goes from the Power Button, down the side to the volume and hold buttons, then to the interconnect board has been torn/damaged. This requires replacement.
There are 2 places where you can easily catch the cable and rip it.
http://d3nevzfk7ii3be.cloudfront.net/igi...
If you look closely here. You will see the cable go over the frame twice. I have made this mistake enough to not make it again.
Score 1
Comments:
Hi All
I recently replaced my IPAD2 screen and digitizer, Also replaced te rear camera and flex cable. Strange issues now is that the rear camera does not work and the power button when quickly pressed does not lock the screen. I replaced the flex cable and camera to fix this very problem. Factory reset and restore also not successful.
Any suggestions please?
by
Add a comment
The latest iPad 2's that are being produced don't have the iPad 2 power/volume flex. They have the iPad 3 power/volume flex.
This flex obviously looks different.
Check for damage to the flex cable and check that all connections are seated properly.
Comments:
Hi, I've re-seated twice made sure that it was free of dust or bits of screen. each time the same outcome all working bar the power button. The power button clicks and feels the same.
If the volume/mute button flex cable had damage I would think that it would not work, I've even taken a macro pic of the visable flex and theres not even what may look like, its been pulled, scratched or poked.
I'm so confused as to what it may be. I've not reset via the settings yet as I've read that some have not been able to get it going again.
Could it be a software issue?
Thanks for your comment, the ipad2 was purchased in NYC 1 year ago so it may of been one of the first to have the ipad3 flex configuration.
by
Add a comment
I have the same issue and am wondering if maybe the power button got too hot when removing the screen? Maybe an internal componant got melted.
Any thoughts?
Add a comment
Hie also having the same problem could I have damaged a cable but I thoroughly checked nothing seems sinister
Comments:
Hie all I have a BlackBerry 9320 and it wont turn on however when charger is pluged in the light flashes red and the keypad also turns on, could it be a damaged LCD but it looks as though its fine, please help.
by
Add a comment
HELLO CAN SOMEONE TELL ME OR HELP HOW TO FIX THIS FLEX CABLE IN THE RIGHT SIDE OF HOME BUTTON
THERE ARE TWO PHILIPS SCREW BUT I ACCIDENTALLY CHOPPED IT SO CAN U TELL WHAT IS THE NAME OF THAT CABLE SO THAT I CAN BUY IT ..... IMAGE BELOW ( IPAD 2 )
THANKS IN ADVANCE
Comments:
that looks like wifi. I broke it when I removed the top screen and had to replace it.
by
Wifi/Bluetooth Cable
by
Add a comment
My husband just replaced my screen on my iPad mini and we'll it's not Turing on you can here the noise when you plug the battery in just nothing on the screen he was very gentle with the lid screen what could be the problem
Add a comment
Add your answer
Ken Dominy will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 74
All Time: 16,235
