External storage options by Seagate, usually connected by USB, available in many storage sizes and form factors.
32 Questions View all
keeps crashing cant retrieve data
hi i have a seagate external hard drive, when i plug it in to a computer,,(any computer) it crashes and slows the system, it takes ages for the hard drive to be reconised and when i try to transfer my music so i can format the drive , it freezes after a minute of transfer and says 20hrs to transfer .... even if i transfer one song.if anyone knows how i can retrieve my data before i format it would be a great help
Comments:
i've got the same issue, you wont be able to fix the disk as if it crashes it dissapears completely
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
What type of connection are you working from FireWire or USB? Try a different cable. If the USB drive has two connections make sure both are connected.
If you have a self powered (via the FW or USB connection) try connecting an external power supply.
As disk drives age they often need a little more power. When running these externals on the older MacBook or MacBook Pro's the current limits of the USB ports can cause the drive to react like this.
Score 1
Add a comment
Most Helpful Answer
Amy, try repairing the drive with Disk Utilities.
Score 1
Add a comment
Add your answer
amy gaughan will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 79
All Time: 2,032
