Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1954 Questions View all
Can anyone explain why my iPhone died?
I plugged my iPhone into the computer for it to charge and next thing you know it is dead!!! don't know if i should buy a new battery or a new phone ;(
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
bgn4895, I suggest you start by tying to charge it with an AC adapter. Should that not work, check the dock connector for debris, like pocket lint, corrosion or bend and broken pins. If that looks okay, get a new battery and see what you get. Definitely cheaper than a new phone...Here are the guides to help you with your phone. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
bgn4895 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 298
