Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
103 Questions View all
Why does my iMac freeze at startup?
***Not exactly sure of model as i cannot access it now... its 27" im fairly sure its early 08-09
The problem started when i was surfing the internet normally and then three fourths of the screen went black and began to flicker rapidly. The audio however kept playing. I decided to reboot via power button.
The imac would start up with the apple logo and the spinning startup wheel, but then vertical and sometimes diagonal lines would come up on the screen and startup would freeze.
I've tried powering up while holding the following buttons:
Option: My hard drive and a recovery hard drive load, clicking on either leads to a start up that freezes as described above
Shift: safe mode; the computer starts up as describes but a bar appears under the start up wheel, loads all the way then the computer freezes.
C: i inserted mountain lion with hopes of re-installing but holding c (and d for that matter) doesn't do anything different
command s: single user mode; i ran fsck it repaired the hard drive, ran it again said my hard drive appeared to be okay, typed reboot doesnt solve the problem
Rebooted manually ran fsck again typed exit, everything seems fine but freezes after " waiting for window server"
i reset the nvram, nothing different... im getting pretty desperate here any help would be appreciated.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Connect to an external monitor - if it boots without problems on the video your problem is in the chain to the LCD or the LCD itself. If it still wont boot, or if it boots with video problems the fault is in your GPU (Video Graphics card) in which case you're looking at some advanced DIY repairs.
If you open the back and watch the iMac - no power, number 1 diagnostic LED on that may also point to the logic board (#2 out) or to the GPU, (#2 on but #3 out).
If this Answer is helpful please remember to return and mark it Accepted.
Score 2
Add a comment
Add your answer
Sarah Fakhoury will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 1,060
