power button wont work
Hi
My Macbook Pro 13 was water damaged a couple of months ago. At first i would not start, but after cleaning it with alcohol i finally got it to work.
but not by pressing the power button. I have to take of the lower case, unplug the battery and the plug it in again while the power supply is attached to the mac. Then i can get the mac to power on.
does anyone have any solution how i can get the power button to work again?
Is it possible to replace the power button? or do i have to replace the entire upper case?
where is the cable for the power button located, maybe i can try with alcohol there?
what to do?
Thanks
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Carefully clean the top case, power button & ribbon cable (you have nothing to lose)- if that fails you can see if you can find just the power button/ribbon cable (advanced DIY) or replace the top case the sell them here for ~$300.00 US.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Add your answer
magnusbjornevaagen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 677
