Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1952 Questions View all
Why won't the small screws on the outside cover come out?
One of the screws at the bottom of my iPhone won't come out. Basically the head has been distorted to the point no screw driver will bite into it enough to remove it from the body of the iPhone so I can do a screen replacement. It also appears wedged in the hole as if it was cross threaded when it came from Apple or else it was jarred making it crooked from being dropped.
Anyone have any ideas?
I considered bore-ing through the screw with a small drill bit. Similar idea to tapping when you break a bolt or something off on a car.
Score 1
Comments:
Thanks for accepting my answer...
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
There is so many different procedures....
Take a look at these links :
Remove a stripped screw
The 12 best ways to remove stripped screws
Or use the Precision Screw Extractor Set. Here's where to get a set:
If this answer was helpful please remember to mark it accepted.
Comments:
Your welcome! I can't wait to try your suggestions!
by
Add a comment
Add your answer
Angeline will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 35
All Time: 9,813
