Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1959 Questions View all
wont turn on when I take it off of it's charger.
My iPhone 3GS fell in some water, it wont turn on when I take it off of it's charger.
Any help?
The iPhone 5 is the current iPhone right now.
Add a comment
1 Answer
Chosen Solution
Pyrus, first thing you want to do, is to stop trying to charge it and to no longer plug it in. This could make a bad situation worse. You definitely should start off with this guideIt is for a 3G but essentially the same procedure for your phone. After that change the battery. A once exposed battery is definitely a cause for plenty of headaches later on. You'll be surprised to find out how many errors a water damaged battery can give you ;-) After that, reevaluate, clean again and see what you get. Should even a new battery give you the same trouble, consider changing the dock connector. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Pyrus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 242
